Warhammer 40K Missionen
DermitdemBlumentopf
Spielsysteme: Warhammer 40K
gerade im Netz gefunden. Einige davon finde ich echt interessant.
Surrounded!
Enemy forces have surrounded your force! Destroy the enemy and capture their command point to reduce their morale and attack co-ordination.
Deployment: Players pick to be the defender or attacker, whoever wins the roll-off picks. The attacker deploys first and can deploy on any table edge, up to 12” from that edge. The defender may set up any way on the board; but not in the attacker’s deployment zone.
Objectives: Each player places their own objective on the table inside a piece of area terrain. The game also uses kill points in the usual manner except for the following: if a player controls his and his opponents objectives they receive + 3 kill points, if the player controls just his own objective he receives +2 kill points. The player with the most points wins!
Ambush
The enemy has ambushed your convoy; reinforcements are on route but you must hold out!
Deployment: Divide the board into 3 equal parts. The winner of the roll-off picks to go first or second; the first player to deploy must deploy within the center 1/3 of the board. The second player may deploy in either or both of the other 2 thirds, but outside the first player's deployment zone.
Objectives: The player going first must keep as many units alive as possible; a kill point is awarded for each unit alive at the end of the game. The second turn player gains kill points for each enemy unit completely destroyed.
Special Rules: Each unit destroyed belonging to the first turn player may be deployed from any table edge within their deployment zone. The second turn player’s armies all receive the Move Through Cover and Stealth special rules. If any units have these rules as standard then these units ONLY receive a additional +1 cover save bonus and roll 4D6 when moving through cover.
Defend
A defending force is battling off a enemy army from its own cities though the enemy is at the gates (and nearly through!) and the utter destruction of the city is at hand!
Deployment: Ruins or buildings must be arranged in a line along one long side of the board. Players roll off and the first player gets to deploy on the same table edge as the ruins, within 12” from the table edge. Once the table edge with the ruins is full then the remaining ruins may be arranged as per normal. The second player deploys his army within 12" of the opposite table edge.
Objectives: Points are awarded for the most ruins or buildings destroyed or remaining at the end of the game. The first player receives points for buildings remaining and the second player for buildings destroyed.
Special Rules:
The first player may fortify one ruin giving a +1 cover save bonus. In addition, all buildings are protected by a force field and receive a 4+ cover save. All of the second player's units have the Tank Hunters special rule.
Hold Out
Enemy forces are attempting to capture and destroy a sacred relic, artifact or anything else valuable to your force – you must defend it!
Deployment: Players roll off to see who goes first. The first turn player chooses any building or ruin on the table; they deploy their forces in the building or within 12” of it. The second turn player may deploy anywhere on the table but must be at least 12” away from ANY table edge, and cannot deploy a unit within 6" of an enemy unit.
Objectives:
The first player must defend the sacred objective and the second player capture it. The second player must get as many scoring units within base contact of the objective as possible. The player with the most units on the objective/in base contact with it wins!
Special Rules:
The first player receives the Stubborn special rule for all units in the army and receives +1 cover save while in the chosen ruin or within 12” (this includes going to ground, ie units out in the open that have gone to ground will receive 5+ cover). The second player receives Furious Charge for all units in the army and defensive grenades.
Bombing Run
As aerial forces bomb the city, opposing forces grapple for control below.
Deployment: Players deploy as detailed in the Spearhead deployment type.
Objectives: Kill points – destroy the enemy!
Special Rules: Stray bombs may land within the battle each player turn. These are treated as shooting attacks, resolved as:
S10 AP2 Large Blast, Ordnance
Firstly roll for the long table edges, assign 1-3 and then 4-6 to each long table edge. Then assign 1-3 and 4-6 to the short table edges. Then roll off for the long table edges and the short ones, whatever wins these are the sides the bomb will enter. Then roll 3D6” for the winning long table edge and 3D6” for the winning short table edge, this is where the bomb will land. The two points must always meet up on the battle field.
I.E long table edge is 18” away from the edge and the short edge is 16” from the table edge, these points will then meet and anything under the template is then hit.
Survivor
A survivor from an earlier battle has been discovered on the battlefield. Each force is attempting to either rescue or capture the survivor! The survivor, however, is a cunning character and trusts no one, not even his own forces!
Deployment: As detailed in the Pitched Battle deployment type.
Objectives: Assign dice rolls to a number of terrain models either i.e 1-6 for 6 terrain pieces of 1-2, 3-4 and 5-6 for 3 terrain models. On each turn on and after the second turn roll a D6, the survivor will then appear in that terrain model according to the dice roll. The survivor can only be captured by scoring units which must be within 3”, even if scoring units are within 3” of the survivor the objective will still move around to different terrain models each turn. The player in contact with the survivor at the end of the game wins!
Volcanic
Enemy forces rage war on the surface of a volcanic planet in its death throes. Everything around is about to be destroyed, one way or another.
Deployment: Use standard 40K deployment.
Objectives: The player with the MOST surviving units wins the game! A point is awarded for each unit, just like kill points.
Special Rules: All units in the game receive the Move Through Cover special rule. All pieces of area terrain count as dangerous terrain as well as difficult terrain.
Any units not in area terrain can be hit by roaring fire from underground, or other debris flying through the air from the exploding planet. At the beginning of every player turn, roll a D6 for every unit not in area terrain. On a 4+ every model in the unit receives a hit from the following profile, calculated as a normal shooting attack but with no cover saves allowed:
S4 AP5 Rending
• Vehicles receive a hit on the rear armor value.
Domination
Opposing forces wrestle control for a vital settlement.
Objectives: Each player must capture as many ruins or buildings as possible. These can be captured by ANY unit, including vehicles and swarms. Units must be within base contact or on a ruins area terrain to control it. Player with the most controlled ruins wins!
