[Bolt Action] Zusatzregeln von Warlord (keine PDFs)
Re: [Bolt Action] Zusatzregeln von Warlord (keine PDFs)
Weitere Regeln hinzugefügt.
kaempes
Spielsysteme: W40K
AoS
Star Wars Legion
Beitrag von kaempes »
Noch was neues:
http://www.warlordgames.com/rules-warpl ... lt-action/
Willkommen bei 40K Regeln. :)
Naja treffen generell erst mal nur auf die 4 weil immer bewegt.
mal ein auszug
WARPLANES shooting
When the plane itself opens fire, the ‘moving and firing’ modifier always applies, so their basic chance of hitting is 4+. Warplanes’ weapons are never in long range as they always shoot from 12” or less from their target, and are never in ‘point blank’ range. Cover modifiers apply as normal – work out the line of sight of the plane from its guns, as normal. Also keep in mind that the target unit can go Down as normal, and that the negative modifier from Pin markers does indeed apply. Note that Recce vehicles cannot use their Escape ability when attacked by a warplane.
When rolling to damage ground vehicles, warplanes always hit the target’s top armour, regardless of their position (which makes them very good against open topped vehicles!).
Some warplanes have weapons called ‘bombs’ or ‘rockets’, which are followed by a number in brackets. These weapons count as a howitzer that can be fired only a number of times equal to the number in brackets, either simultaneously or in separate turns. For example a bombs (2) weapon can be fired twice during the game, either both at the same target in the very same turn, or once against a target in a turn, and then once against another target in a later turn. Bombs count as medium howitzers, rockets count as heavy howitzers.
Regeln für Massenschlachten hinzugefügt.
Regeln für War Reporters hinzugefügt.
Helmhold
Advanced Squad Leader
COIN - FitL, LoD, ADP, FS
Beitrag von Helmhold »
Oberst Manuell hat geschrieben:Regeln für War Reporters hinzugefügt.
Die erinnern mich irgendwie an die SAGA-Barden. :)
Airborne Reinforcements hinzugefügt.
Steiner hinzugefügt. Hier auch noch mal das FAQ eingefügt (das alte war auch hier im Thread)...
